Hey guys,
I run a different gearbox to you in my FWD pulsar however they all function the same.
Ill try and be as discriptive as i can.
When the car is running, clutch fully in ( ive already adjusted the clutch cable to eliminate that problem) gears will not go in. They do not crunch and they do not grind, they just dont go in.
The issue is intermitant and only happens sometimes.
My clutch feels the same as it always has and still functions.
If the car is not running i can put all the gears in fine, with the clutch pressed or depressed however as soon as the car is running, sometimes, the gears will not go in and reverse will grind.
Ive been told the clutch has collapsed and is not fully disengaging however im thinking more along the lines of something like the selector fork in the gearbox however when the car is not running the gears go in fine so ive kinda ruled it out.
If anyone has experienced something like this before or has a suggestion before i rip the box out or start ordering stuff i dont need it will be much appreciated.
