unstable idle, can't rev high rpm.. need help
E
easylife
idle rpm will go up and down between 1000-1500rpm, sometime ok.
sometime can rev 6000rpm still ok but sometime only 3500rpm and something like fuel cut / misfiring happen.
Can Be O2 Sensor???? Fuel / firing system????
Changed MAF Sensor, Coil, Spark plug & Cable, Distributor.
ECU Error Code: 12, 33 ( if not mistaken)
Sard fuel Regulator , 3.6bar
HKS Air Filter
Bosch HIgh Capacity fuel pump
Apexi N1 Muffler
2.5" exhaust pipe.
Standard ECU
NGK IRIWAY 7
33 doesn't exist, probably 34, but I'd check again to make sure.
If the codes come back, obviously the problem is still there. The fault codes mean there is a problem with the component or its' wiring, so if you change the item and the fault is still there, it's probably the wiring.
You can do the fault code check yourself with a paperclip. Read the sticky at the top of this section.;-)
