underbody
olliecast
I'm on a course with somebody from weetabix.
Seal it with underseal. Make sure you give it a good wire brushing first
skiddusmarkus
Waxoyl, goes on easy enough with a brush or buy the pump action spray thingy.I've done inside the boot floor, under the main carpet, arches, where the OE battery was and underneath the body and have no rust.
eastwood
I used Waxoyl I completly stripped my car inside and out and done the whole thing easy to use but a messy job............
shroom
What you can do is heat it up a little and put it in an electric spray gun bit like for fences then it goes on realy well and takes minutes, you can't get much on with ze brush, waxoyl is good stuff though its a cnuts trick to hide stuff with it
