from memory the top small set of plugs go on the same terminals as the heated screen switch and in the same order as they are for the illumination then the two thicker wires are for the actual switch, cant remember which way round they go just try it either way, if you get it wrong the light for the foglight will be on all the time so just reverse them and that should be all
