TWO WHITE PLUGS
gtir_john
anyone know what the two white two pin plugs are, they sit under the inlet manifold, one directly above the starter and one bout six inches further up the loom towards number opne cylinder, they are both female connections and they arent the ones that plug intp the two colour coded plugs on th manifold, any help would be great as i cant put the fannymold on till i no, cheers
also there is a pipe that runs round the back of the inlet manifold bracket it sits in two clips, wats this one for
The white one is for the det sensor on the back of the block :wink:
Are you sure the other one is white? I thought it was a greyish colour :? Once you've got the det sensor one on it should be pretty self explanatory anyway. You cant go too far wrong unless you're a complete numpty :lol:
Which pipe are you on about? The one that comes up behind the plenum and goes to the brake servo :?:
If you can wait until tomorrow evening i could tell you for sure :wink:
gtir_john
problem solved, ones the knock sensor and pther is for the little black box under the inlet, anyone no wat this is, cheers
