pointless.....utterly pointless. waste of money time and good welding talent.
you can bearly fit a proper manifold and turbo in the pulsars virginal engine compartment...much less 2.
Another point.....i am a bit cynical but bear with me.
I bet you arent willing to spend 600-800gbp on a proper equal length manifold for a single turbo.
If i am wrong then i guess you will be willing to spend twice that on just the manifold to fit 2 turbos. Not to mention the turbos them selves. then there is the question of the radiator.....you sure as hell wont be able to keep it in the front that means a block off plate for the origional water pump and an electric one with custom rad and ducting with about 20ft of hose to run and burst. then there is the intercooler and the piping...hahahah work that one out.
all for nothing...all the weight and complexity you have added will amplify the terminal understeer AND reduce any chance of you driving anything called reliable.
get a proper manifold...hell even polish up your standard one, a nice ball bearing turbo and compliment it with a good engine managment, fuel system, ignition and dyno tune it.
You want response and balls to the back of your throat power.....get JWT's stroker (2.4l) or a company called Golden Eagle will be making a 2.7L kit as well (deck plate, liners, custom timing chain....lots of machining) and an Garret GT42.
But as said above i doubt you will shell out for it...its just not practical.
