Trip
Since started racing i always considered the gearbox's i used are too high ratio. After a chicane i was ending up exiting in 2nd gear and just wait for the turbo to spool . The other option is to put it in first but that needs more precise(syncronized) gear change and if not done right, time can be lost.
So i was looking into a GT2860RS turbo to help reduce the spool when exiting in second gear. Since then I managed to get hold on a Close ratio gearbox with similar gears ratios of an RB box. This "should" help me select that missing gear i always craved for between 1st and 2nd. It should also shift my usable rpm higher up the rev range.
Now my question is, should i still consider a GT2860RS or get a bigger turbo to shift power band in the top RPM range ? I am not after BHP numbers, I am mainly after response and area unde the torque curve where i need it most.
