turbodaily
how do most people go about removing the turbo from an r? is it necassary to remove the bumper? or can i get away with just removing the slam panel and radiator?
thanks
thanks
turbodaily said:how do most people go about removing the turbo from an r? is it necessary to remove the bumper? or can i get away with just removing the slam panel and radiator?
thanks
That what im doing. Stock ecu , stock injectors, walbro 255 and 4 bar fuel pressure . I wouldnt run over 1 bar without a wideband tune and dyno just for insurance.turbodaily said:nice 1. im taking the r off the road for a couple of weeks to sort some bits out ie brake pads, rocker cover. and get a 3071 turbo on there.
will the standard injectors be ok with a 3071 on 1.1bar? im planning on getting some 600's but wont be for a little while as il need to save for a remap too.
turbodaily said:any idea how long a job it is to remove the turbo on an r?
I Can do it in about 30 Mins tops depending on if there arn't any dicky bolts.turbodaily said:any idea how long a job it is to remove the turbo on an r?
stu-gtir said:I Can do it in about 30 Mins tops depending on if there arn't any dicky bolts.
Ha Yeah, removed turbo's alot in the past thanks to dodgy turbo rebuilders in Blackpool:twisted:Odin said:Yes those of us that have done it a few times can do it very quickly, But I don't think many if anyone could do it in 30 min's once you've had to bugger about with the bl00dy oil/water lines.
I reckon a good hour is a fair time if you're handy with the spanners and are being careful with the oil/water lines.
I tend to undo a few bolts then stand their looking at it for another hour with a cupper shacking my head :lol: :lol: :lol: , Then do a few more bolts then another cupper ;-) , You get the picture :lol: :lol: :lol: :lol: .
