turbo question
thehybridsnail
hey there people wanted to know wot would i have to do to fit a gt2871r?? like manifold intercooler flange and air inlet. or could i use my current set up. thanks guys
Spikey
Well a gt2871r can give you from 350-420 pony's so you need injectors and afm then a remap to support this.
Also fmic uprated fuel pump and so on... Why is it this particular Turbo your after?
thehybridsnail
got all that, my standard turbo has given up. had a good deal on 1. i have 740cc injectors, huge front mount, fuel pump. been remapped already. what i mean is can i use standard manifold, my currentair filter intake and intercooler pipework with this turbo?? cheers
shroom
The outlet of the turbo could be different (larger) to the stock t28 3 bolt type, but you could easily modify that, it depends on what size housing you have brought, some of the larger ones require mods to the block or gearbox mounts to fit in, or spacers on the manifold.
