I've had a quick search but couldnt find any advice which really fits my question so apologies if its already been posted.
Having not long had my gtir, I have started going over bits and pieces here and there, cleaning, checking etc etc so if something is wrong I know about it before it goes bump big style. So after removing (angle grinding) the rally guard off the front, I unblolted the turbo inlet pipe off to get access impeller shaft
Now there seems to be some minor play, it reallt does feel minor but you can def feel it isnt solid? also there is some oil in the outlet into the top mount. So i presume the seals and bearings are on their way out? As a side its boosting fine, and spinning the impeller doesnt give any grinding or rough sounds.
So being my first turbo car I need a lil advice? Should it feel 100% solid? if so should keep my eye open for a turbo at a good price? or panic and buy the first one that comes along? or just wait until it really makes some horrid sounds. I have a second car so being off the road is not really issue.
Thanks in advance
Thanks in advance
