T
Toady
i know most turbo's will tend to burn oil if left to idle for a while when oil temp is warm, and if you boost it and let off then the turbo will let oil thru and you'll see it smoke, but does the R do the same if the turbo goes? only mine is fine when idling, and when driving normally, but when boosting the engine seems to be burning a bit of oil. it may be cos the car has not been able to rev over 4k for about 5mths due to a running problem, but it doesnt seem to boost like my old r did either?
anyone on here blown their tub? if so what did it do?smoke on idle, run down, or boost? cheers!
