I have the protech log mani so the turbo is top mounted. I need an oil feed banjo bolt so what i plan on doing when i get the turbo is to go down to talbot hydraulics by the steel works and see if they can do it. they are a bunch of good guys there who helped me alot for parts in the last six months.Dobby mate, I need the same stuff. What manifold you got, and where does the turbo sit? Drop me a pm if you don't wanna clutter the thread.
If you are going to fit an oil feed restrictor you will want a female treaded hose to attach to restrictor not banjo bolt style fitting. I got the correct hose from Ben at Hose solutions to fit the restrictor.I have the protech log mani so the turbo is top mounted. I need an oil feed banjo bolt.
