Turbo oil return
JU5TY
What type of piping have people used for the oil return pipe on non stock turbo’s? Also does it matter if the piping doesn’t necessarily flow down more across? i.e. is it under pressure in that it will be forced back into the sump or is it meant to run down the pipe using gravity?!
jiw
samco sell pipe designed to be used with oil, only available by the metre though, what diameter do you need, i have the demon tweeks catalogue here with all the prices, jeff
JU5TY
Seen that but says 'Not for continuous immersion in fuel or oil', which I guess rules it out. :(
D
disco dave
i used 16 mm int dia samco co hoises u must noit restyrict this pipe in any way as its a gravity retyurn pipe and if u stall it il make turbo seals leak cos it cant get rid of oil quick enough
ashills
justy speak to ginga or mem as they will had to have made them up, i had a very strange bit of copper for mine but not really recomend it kieron may have a pick if u ask him as he has the turbo now
