A few basics for you so:
On standard manifold placemetn or similar turbo placement form tubular manifold, the biggest turbo that will fit will have a 2.75" inlet, or 3" tops.
After this the gearbox casing is a problem and either needs to be shaved as some have done, or the manifold needs to be cut up and extended to move the turbo a bit.
The latter means moving intercooler pipes, customing down pipes as well as extending the manifold. Basically, an expensive job.
The standard GTI-R turbo is good for around 330bhp give or take 10bhp.
This is at 1.2-1.4bar.
To get more power, you will need to uprate injectors, air flow meter and turbo.
- assuming you've already done the collection of exhaust/boost controller/air flow controller etc to get to the 330bhp. Front mount intercooler in there too..
For safety then you will need an aftermarket ecu or piggyback job - Apexi Power FC being the most common, or GReddy Emanage.
Then you have sundries such as tubular manifold, external gate for better boost control etc etc...
I haven't a clue on the turbo's you've mentioned but perhaps some more knowledgeable lads will post up shortly when they see this.
If they do work then let us know, but I'd have thought it would've been discovered before now.... ?
