Turbo/induction pipe
keastygtir
Hi Guys
Can I block off the 2 pipes that feed into the induction pipe?
One is quite small 5-6mm and the other one is 15-20mm approx.
Thanks
yes one is a bleed off pipe from standard boost solenoid and the other is breather from rockercover inlet (just make sure the breather isnt blocked from rc side)
you should really run a filter from it or run it to a catchcan or youll have an engine bay with oil all over it.
just blank the bit off on the main induction pipe.
