pulsarmad20
Hi
All
how do i set the turbo actuater/test for faults??
thanks
sam
								All
thanks
sam
You can use a foot pump to test but be very careful not to put too high a pressure in as you can easily damage the diaphram. The actuator arm should start to move around 0.8 bar or slightly above. Depends on the rating of it. The arm should hold it's position under pressure.Hi
All, how do i set the turbo actuater/test for faults??
thanks, sam
