tunning
ashleygtir
hi, i have a standard R and would like a little more poke from it, but would also like to keep reliablity. so what do i need and what sort of power would be safe? also does having a short shift help improve the life of the gear box? thanx
Just go the 1bar route, service it regularly and it should be fairly reliable.
(Filter, exhaust, clutch, fuel pump recommended, plugs, front mount if you want)
Short shifter wont improve the life of the gearbox. May help reduce it through more missed gears tho.
N
Ninja_tune_factory
Hi Ashley,
we have just done a R with simalar mods to what carl listed and it made 314hp.
seen your in south wales mate im down the road in newport
Cheers Lionel.
mad max
you dont need a fmic on 1 bar as for the clutch (how many miles has it had done )you will find if you turn up the boost the clutch is the first thing to go if all else is set up right
ashleygtir
Ninja_tune_factory said:
Hi Ashley,
Cheers Lionel.
ive seen a black R with the sump guard thingy, was that yours?
N
Ninja_tune_factory
Nope my ones white mate with 17" no spoiler:roll:
If you need help or anythink pop down:thumbsup:
N
Ninja_tune_factory
nismoboy said:
314bhp @ 1 bar lol
you`ll only get 280 tops with one bar boost exhaust and filter.
If you read what fast guy has put in his post your find he listed a little more the just exhaust and filter:roll:
and yes one of are cars did make 314hp@1bar and it has very limmited mods
Lionel.
F
Fusion Ed
If you want to think more long term rather than the 'turn up the boost and prey' method uprate the clutch and put an e-manage on it. Then you have a basis by which every other mod can be accounted for - properly.
ashleygtir
whats e-manage? is it like the apexi boost controller?
GTiR_Mic
Ricky_GTi-R said:
E-manage is a whole new ECU;-)
I think you will find that the E-Manage is only a piggy back unit mate. it is the Apexi Power FC that is the replacment ECU ;)
Mic
