tuning guide help
C
CHRIS_2010
RIGHT AT THE MINUTE.. my pulsar is running pritty much standard...
except from a full exhaust system and a decat..with a hks cone filter..
i have ready to go on it.. a apexi avcr..also a apexi boost computer..
just wondering what else i would need .. to run reliably
also what sort of boost should i run and what bhp i could achieve..
any help would be good..
chris.
Fazz
do a search... all depends how muchb u are willing to spend.
from where u are the next step would be,
Uprated Clutch, Uprated Fuel Pump, Fit the Apexi aVC-R Boost Controller, and maybe an Apexi SAFC Controller or a piggyback ecu.
This ensures you are running safe..
Map to about 1bar then should see at least 280bhp.
after that its up to your wallet... - bigger turbo, ECU, bigger air flow meter, bigger injectors, depends what bhp is desired.
