just wondered on peoples opinions on the md214(ie stage 5) and the md196(stage 6) turbo`s :?:
md214 roller bearing turbo,special 54mm gt25 76 trim turbine,high flow 76mm to4s compressor wheel (53mm inducer), reprofiled compressor housing, t28 compact gt series roller bearing core,left hand thread "low interia" shaft and wheel fitted with stagged gat/total seal turbine end piston ring fitted, 0.64 a/r turbine housing uprated 14 psi actuator. chioce of uprated actuatorand modified wastgate.capable of 420bhp.
md196 roller bearing turbo,special 54mm gt25 76 trim turbine,high flow 76mm to4s compressor wheel (53mm inducer),large 0.70 a/r reprofiled compressor housing with 3 inch inlet and 2.5 outlet, t28 compact gt series roller bearing core,left hand thread "low interia" shaft and wheel fitted with stagged gat/total seal turbine end piston ring fitted, 0.64 a/r turbine housing uprated 14 psi actuator. chioce of uprated actuator with extra strong bracket and modified wastgate.capable of 450bhp
compressor inlet and outlet hoses require modification to fit this turbo in addition to the oil drain pipe flange as mentioned above. Engine remapping is essential with this turbo for best results.
does anyone know at what rpm will these turbo`s make full boost? ie using 1.2 bar of boost.
cheers nis.
cheers nis.
