Cambridge_pulsar
Sorry I know this has been covered a million times but need clarification of the gearbox filler plug. Only possible place I can see is almost directly under the dump valve pipe towards the back of the box, a plug with a square recess is that it? Also on the rear diff there's 2 similar plugs, one facing the back and one slightly higher up to the side, are they the drain and filler plugs? maybe someone could come up with a definitive beginners guide to locating these as it seems to be a common problem...
