Transfer Case Questions
alphadrex
Hey Folks,
So, I'm in the middle of a clutch job here, was on the reinstall, and found that my transfer case was leaking between the intermediate plate and main housing. I couldn't leave it leaking, so I split it and resealed it. This is where my questions come in for you gurus out there.
When I split the box, the ring gear & shaft came out attached to the plate. Counter shaft stayed put, but I didn't mark the gears on removal. I noticed on reassembly that the gears/shaft seem to have marks on them. Is the countershaft timed to the ring gear/shaft?
Secondly, on reassembly, I was very careful to ensure all shims were reinstalled, but the box appears to have been sealed with rtv sealant. Wouldn't using a sealant such as that make proper shimming impossible as there is no way to gauge/ensure consistant thickness of gasket between intermediate plate and main case? (Also, would not the same situation apply to the front diff. housing?)
Lastly, if all I am doing is resealing the intermediate plate and case, and reinstalling the front diff./housing, are there any checks/measurements to perform before returing to use?
I hope that was as clear as possible, please advise. Thanks all.
alphadrex
keastygtir
Hi, the question is a bit out of my league but it might be worthwhile if you haven't already posting to the facebook group also.
