yep nearly all the above thanks thats sorts that outWhats your symptoms? My R is making a cluncking & banging sound from pasenger side front wheel when setting off from a junction with abit of steering lock on & pulls on the steering wheel! also on slight left hand bends. Ive checked ball joints, drop links, & changed cv joints. etc. So ive put it down to being the FRONT DIFF/TRANSFER BOX! Maybe yours is the same or are you having different issues?
In gearbox?? yep some1 said it could be! but im justhopeing its not :doh: or its a big job! its fine when the cars moving in a strait line. can be on & off boost as much as i want & its fine??could also be the centre diff.
