torque settins for d/s nuts??
Gaz gtiR
ive done a search on here & cant find anything tellin me the torque settings for the DRIVESHAFT nuts?? dous anyone know??
cheers
Gaz :)
splmum
Prop-Shaft to transfer coupling, minimum 34Nm (25 lbs.ft.), maximum 44Nm (32 lbs.ft.).
I believe they are the same for the prop-shaft to rear differential.
Think I used a 3ft bar, either swing off it or jump up and down on it ;-)
I did something similar; socket on the nut, and then used my wheel brace as the extension... and stood on it.
That fixed the little bugger!
johnsy
drive shaft nuts,
ah not bolts then lol, so the big fooker on the end! i used an impact driver and a braker bar just to make sure
Gaz gtiR
ahh ok ill use a breiker bar then :) ... johnsy is rite aswell tho what are the torque settings for the 6 bolts on other end of driveshaft?? i forgot about them. OOPS.
