G20_GTI-R
Does your boost taper off in high rpm's? I hold 1 bar (14.7 psi) then it starts to slowly drop to about 11 psi in high rpm's. Is this just because the standard turbo is small?
if you have a better idea on why the boost is dropping i would like to hear it, he could take his car to a garage and spend money and still not solve the problem, you are right that you dont need a HKS actuator to run 1 bar you can do it with a stock one and a bleed valve or boost controller but you can get spikes due to the weak (and weakend over the years) spring in the stock actuator, look into the forge ones as gtirx2 suggests, they will do the same job and likely to be cheaper.CruiseGTi-R said:Dropping to 0.7ish bar at high rpms from 1bar means something isn't quite right.
Don't need to run an HKS actuator for just 1 bar, spend your money on solving your problem.
