Mikey_pulsar
When i hit 1Bar boost i can hear a ticking noise, it doesn't happen until exactly 1bar and then carrys on round to 1.2Bar...is this my injectors?
Thanks,
Mike.
Thanks,
Mike.
I does sound a bit metalicky...if there is such a word? :lol:steve963 said:pinking: light metalic clinking sound, ignition too far advanced, spark too soon hence combustion trying to push piston back, piston rattles against bore over TDC, not harmful at light throttle/loads if corrected
I've only just got it running over a bar mate, i kept it at 0.8 for a while, then wanted more :lol:pulsarboby said:has this noise only just started mike? if so then you may have a fuelling prob somewhere (assuming it is actually pinking that is). could be a defective injector or weak fuel pump.
best to get it checked out as people have suggested already!
so you had to alter your base timing?Mikey_pulsar said:sorted it...was the ignition timing 8)
