thinking of sticking the thing on pistonheads
nimhbk
right have not got the patience to carry on with this bloody thing! timing is slighty out i think
was thinking of putting it on for about two thousand five hundred am i taking the pi££ at that amount should i be aiming slighty or a lot lower
http://s299.photobucket.com/albums/mm312/povanic/
it has
Whiteline springs all round
whiteline strut braces front and rear
Gab Front shocks
560 injectors
z32 maf
Apexi air filter
Ecu from ed at fusion Motorsport
New bottom end purchased from Johnsy on the other site
Rear samco hoses
cp pistons
acl bearings
hks exhaust cam
hks 1.2mm head gasket
brand new oil pump
brand new cam chain
brand new tensioner
brand new water pump
walbro fuel pump
2.5 blue flame exhaust
Exedy hyper single clutch with the flywheel
mocal oil cooler
oil relocation kit
radtec intercooler with brand new custom made 100% uprated copper rad
hks bov
hks evc 5 was £500
sparco evo xl seat with brackets
sparco passenger seat the cheap one with custon rails from NZ
sparco harnesses
sparco steering wheel
couple of hks gauges
wilwood brakes
uprated rear discs
buddyclub p1 15inch alloys
it has no rear Interior
brackets for the rear seats have been taken off,
The heater system has been removed
and the windows are up the shiter
what price do we think guys any help will be appreciated
pulsar_stu
What's wrong with it? Running lumpy? Or not starting?
What have you done? Engine out rebuild?
What have you tried so far?
Has the cam timing been setup right?
nimhbk
running fairly well till yesterday when we changed the timing
and yes mate brand new bottom end just fed up with the bloody thing now i recon the tdc was slighty out when we put the cams in was going to take it down to bobs but not sure about spending more on the bloody thing
pulsar_stu
Why did you change the timeing yesterday? If it ain't broke don't fix it lol
Have you tried putting the dizzy back to what it was yesterday?
What have you set it to to make it run shite? 20 deg?
Is the tps set ok?
pulsar_stu
I know how you feel mate, it can be one thing after another.
Seems like you've done all the hard work now tho, would be a shame to let something like timing get to you now!
At the worst you will just need to re set the cam timing.
What was the timing set to before you changed it yesterday and have you used a timing gone to change it?
danr
sell some spangly bits to pay bob to do it. will still pull like a train on standard ecu.
then you can enjoy it while finding the bits you sold, probably cheaper!!
chin up an all that stuff ! :_)
give me a bell nick
if you can get her down to me il have a quick checkover for you and hopefully will be able to tell you there and then whats wrong with it foc.
then its up to you if you want us to sort it, flog it, or whatever
but seems a shame to jack it all in after you have come so far with it
