thermostat!
Gaz gtiR
Just bought a new thermostat for the R & it says its a 77 degree. is this the right temp for standard? also has 170F stamped on it. whatever that means?
wrc
Fahrenheit mate....And yea that's about the right temp you want, I think I've got a 78 deg in mine and she's fine.
Gaz gtiR
I knew it was something to do with temp but ive never looked in to renewing thermostats as ive always had renault 5 turbos & you throw the thermostats away in them because of the headgasket isues they have as the run to hot! Just wasnt 100% sure
Digitalfaze
is that not the whole point of a thermostat? open when things get hot?
Gaz gtiR
No R5 Turbos tend to run very hot, so you dont realy run a thermostat as they get up up to temp well enough without the stat! & As they are proan for headgasket failier the stat is just classed as 1 more thing to cause this!
So never realy messed around with thermostats, Thyats why i asked this question because i know the GTiR should run a stat :)
