anyone got any tips on how to take off the tip of a mongosse exhaust off, mines stuck solid
rossdj1983 New Member Aug 11, 2007 #1 anyone got any tips on how to take off the tip of a mongosse exhaust off, mines stuck solid
Dooie Pop Pop New Member Aug 11, 2007 #2 you need a big **** off heavy rubber mallet one bashes the other person twists the tip, if your on your own.... :lol:
neil240z Member Aug 11, 2007 #3 you really need a ramp, the centre section has to be taken out at such an angle your car has to be very high off the ground (with a jack that is) good luck..... Neil
K Keira New Member Aug 11, 2007 #4 drop the subframe and lift the car up off it..easy peasy...can pull the whole lot out pretty much straight then 8)
P pulsarboby Guest Aug 11, 2007 #6 yep 4 bolts and the 3 to each shock on the inner turret, then it will drop down!
