tacho wire check
nimhbk
The wire into the back of the cluster that powers the tacho if working as it should, what values should it put out on a multi meter
watoga
There are 3 wires going to the tacho:
The yellow wire should be 12V as it comes directly from the ignition live.
The black wire goes directly to the chassis earth - so check it for resistance rather than voltage.
The blue/black wire which goes to the ECU gives approximately 1V at idle, and nearly 3V at approximately 2500 RPM.
Check here for more details:
http://www.gtirworkshopmanual.com/default.aspx?v=2295
Hope this helps,
Dave
