SURVEY !!! - please take part
hmmm
Right...just to see what the most popular flluids and oils are...just add your oil/fluid in order. Hopefully this will help in deciding what to use as ppl can see the most commonly used products. If i missed anything..pls let me know...thanks
1. Engine Oil
2. Brake fluid
3. Clutch Fluid
4. Power steering Fluid
5. Diff Fluid
6. Spark plugs (and what boost u r running)
7. Brake pads and disks
8. Leads, Dizzy and Rotor arm
hmmm
ok i will go first...
1. Silkolene 15w50 race synthetic oil
2. Dont know :oops:
3. Dont know :oops:
4. Dont know :oops:
5. Dnnt know :oops:
on service history it says change all transmission oils but no name for each one
6. hks Iridium spark plugs (standard boost)
7. EBC grrenstuff pads and ebc grooved discs
8. Standard Nissan leads, Dizzy and rotor arm
coxie
millers 10ww 60
racing blue fluid
standard clutch fluid
standard power steering fluid
millers transmission oils (not sure on grades)
hks iridium s40i's @ 1.2 bar boost
full wilwood brake kit (310mm)
all standard nissan ignition parts (except plugs!)
Shaun
Millers 10/60
DOT 4 synthetic
DOT 4 synthetic
Standard
Not sure
NGK 'R's(Standard boost)
3G Disc's
Standard Pads
Magnicor Leads
Nissan cap
Nissan rotorarm.
jasegould
1. Engine Oil - CASTROL RS 10/60
2. Brake fluid - Possibly lockheed? Whatever we have at work
3. Clutch Fluid - see above
4. Power steering Fluid - Dexron 2/3 ATF??, again dunno, its only PS fluid.
5. Diff Fluid - ?
6. Spark plugs (and what boost u r running) NGK p7rfb (IIRC) @ 1 bar
7. Brake pads and disks - ?
8. Leads, Dizzy and Rotor arm - Bluespot?? I cant remember but its blue something :roll:
And REDLINE gearbox oil
samellio
if ur hard on ur car i'd run fully synthetic engine oil (5w40)
I found runnning castrol RS (10w60) etc means oil heats up quicker- good for short journeys- but really bad for track and fast road...
I found running running 5w40 would give the lowest oil temp round track and fast road, but it took longer to heat up :!:
1 mobil 1 15/50
2 standard
3 standard
4 standard
5 Castrol syntrax driveline
6 standard/ under 1bar
7 standard
8 standard
J-GTi-R
1. Engine Oil - Castrol RS 10W-60 or Millers CFS 10W-60
2. Brake fluid - AP Racing Dot 5.1
3. Clutch Fluid - Any
4. Power steering Fluid - Castrol stuff I have in the garage
5. Diff Fluid - Standard
6. Spark plugs (and what boost u r running) - NGK PFR7B (standard)
7. Brake pads and disks - Wilwood Poly Q and grooved and drilled disks (after I shagged the solid ones)
8. Leads, Dizzy and Rotor arm - Nissan standard items
1) Engine oil- Morris 5W/40 FS
2/3) Brake/clutch fluid-Dot 4
4) PAS-ATF
5) Morris LS90
6) Not changed yet
7) Mintex
8) Standard
Use Morris oil cos i get it free at work, and its good enough for all our EVO's
jasegould
Prob coz this question (or similar) have been asked a thousand times before....if u do a search youll find all you need to know :D
hey
you forget gearbox oil!!
Kev.
memski
1. Engine Oil - Millers 10w60
2. Brake fluid - Lucas Dot 5.1
3. Clutch Fluid - Dot 4
4. Power steering Fluid - Shell dextron atf III
5. Diff Fluid - Millers 85w90 (iiirc)
6. Spark plugs (and what boost u r running) - HKS s45i - 1.4bar
7. Brake pads and disks - Pagid fast road pads, hispec 300mm
8. Leads, Dizzy and Rotor arm - Stock nissan
gotoinstant-redline
1. Engine Oil 10w40
2. Brake fluid DOT 5.1
3. Clutch Fluid same
4. Power steering Fluid halfords finest auto box oil :)
5. Diff Fluid they all use diffrent fluids! but the ones i changes recently were 75w90 for the box (castrol syntrax) and just 90 for the rear diff.
6. Spark plugs (and what boost u r running) hks fancy ones,heat range ?? running 1.7bar
7. Brake pads and disks stock discs, mitex pads :( (i'm a bad boy!)
8. Leads, Dizzy and Rotor arm good nissan leads, rotor and cap.
thats off the top of my head.. but i think its mostly right. cant remember what the plugs are so i cant be more helpful than that.
L.
GoToInstant-Redline
1.7 bar
:shock: what power and mods are you getting/using :?:
