Speed junkie
Hi does any1 no how much a super hybrid turbo costs, and where i can get 1 from, also what will i have to modify to support it, if i do get 1
thanks
thanks
Speed junkie said:cheers mate
You might be putting the cart before the horse here. Difficult to say what you need to support the turbo as we don't know what spec you've got. A super hybrid turbo might sound cool :roll: but I'm guessing if you didn't know what a bar was you're pretty new to the game. Your standard T28 will be good to around 1.2Bar (Though it will wear out more quickly). To support 1.2 bar you will need better fuel control. This would give around 290-320hp depending on your engine spec.Speed junkie said:Hi does any1 no how much a super hybrid turbo costs, and where i can get 1 from, also what will i have to modify to support it, if i do get 1
thanks
campbellju said:You might be putting the cart before the horse here. Difficult to say what you need to support the turbo as we don't know what spec you've got. A super hybrid turbo might sound cool :roll: but I'm guessing if you didn't know what a bar was you're pretty new to the game. Your standard T28 will be good to around 1.2Bar (Though it will wear out more quickly). To support 1.2 bar you will need better fuel control. This would give around 290-320hp depending on your engine spec.
320hp is relativley easy and safe. To achieve the spec a super hybrid turbo (360hp?) needs to justify bothering means it gets very expensive very quickly. Yes some people on the forum are achieving big power from standard internals now but the other 99% including myself have a trail of pistons, clutches, controllers or gearboxes behind them.
Save yourself some money and read through all the tuning FAQ's before you buy anything, that's what they are there for.
Cheers,
Jim
Was tempted to just say do a search but it is Friday.vpulsar said:Trust Jim to do a proper reply :shock: :lol: .
Thanks a lot people. I have a full mongoose system, a KnN induction kit, i have just bought the diamond grooved and drilled sports brakes, and am looking to get the helix organic sports clutch, can you tell me what type of fuel system i will need and how much it will cost? also how much power will a forged front mounted intercooler give?vpulsar said:campbellju said:You might be putting the cart before the horse here. Difficult to say what you need to support the turbo as we don't know what spec you've got. A super hybrid turbo might sound cool :roll: but I'm guessing if you didn't know what a bar was you're pretty new to the game. Your standard T28 will be good to around 1.2Bar (Though it will wear out more quickly). To support 1.2 bar you will need better fuel control. This would give around 290-320hp depending on your engine spec.
Cheers,
Jim
All the above is very very good advice Mr Speed junkie as Jim has said it starts to get very expensive when you start turning up the boost, First thing that will go is the standard clutch, 1 bar is far as you can go with out other mods and the standard turbo is fine for that .
Over 1 bar and you will need some form of fuel control to go with your boost controller. If I where you i'd make sure you had a good exhaust and induction kit fitted as my first mods, Then before you start turning up the boost get some new brakes otherwise your kill yourself, Standard sunny/pulsar breaks are about as much use as a choc teaspoon.
rob
Forge front mount will give you a bit more torque and power but not much, Wouldn't bother inless you are planning on going for more than 1.2 bar really or spend a lot of time sat in traffic. I'd also go for the hybrid kit over the forge anyday it's a lot cheaper and has a far better pipe run in my opinion.Speed junkie said:Thanks a lot people. I have a full mongoose system, a KnN induction kit, i have just bought the diamond grooved and drilled sports brakes, and am looking to get the helix organic sports clutch, can you tell me what type of fuel system i will need and how much it will cost? also how much power will a forged front mounted intercooler give?
andy123 said:How do you get up to 1 bar without a boost controller? you have to adjust the actuator or something?
