Just replaced my rears with some EBC's from Demon Tweeks £97exc VAtHi,
I am looking for some new front brake pads and rear disc's for the Sunny GTI-R. They must be Genuine Nissan items, new and unused.
I have checked with my local Nissan garage and they are unavailable now.
You can buy oe fitment discs from motor factors or ebay.You can just use 10.1 inch reardiscs off a gti with a gti pad carrier. It shifts the stock caliper inward 12mm approximately to line up with the disc with taller hat. You might need to trim the heat shield a little to make it fit. It is likely the cheapest long term solution to rear discs
I use a maxima 11inch rear disc with maxima pad carrier and the stock caliper for a slightly larger rear disc to match my 11 inch front 4 piston kit
