Hi guy's,i changed my clutch and flywheel the other weekend and for the first 2 days the car seemed fine,but one morning i started the car and it was stuggling to tickover,as if there wasnt any choke.And if i pulled up at a junction the revs would drop to around 600 and then bounce up and down before settling after around 5-10 seconds,it also had a flat spot between 2000 and 3000revs.I monitored it for a couple of days and changed the MAF and Coil with known good ones to no avail.I then noticed that the AFR gauge was very sluggish so put it down to the Lambda sensor which i changed today for a secondhand one and all seemed to be ok until i started it from cold again.The AFR gauge now seems to be working as normal and the flatspots seem to have gone,but its still stuggling to tick over.I've also check the boost and vacum pipes and all the plugs that were disconnected when i had the gearbox out.Any ideas?Oh and it had a new coolant sensor around 6 months ago.
