Cambridge_pulsar
Wrong section I know, sorry!
R has been running pants for ages, went to powerstaion a while back and after playing with the timing got it up to 245bhp at 1 bar!!! Not good, The guy said the exhaust was restricting the engine from about 4000rpm upwards and needed replacing. So replaced it with a mongoose but doesn't feel much better, the boost kicks in and it pulls but still struggles at higher revs. My thoughts so far are... The frontmount pipework is too narrow or twisty although it's still wider than the turbo pipe and it's meant to be rated upto 400bhp I think, leaking boost, although that should be obvious shouldnt it? I have a forge dump valve, heard they can leak. Any other suggestions? The guy at powerstation did say the fuelling was spot on. Cheers
