still crap oil presure
Changed the filter as it was way to small which we thought was the problem....No Good
Right oil sump is of no dents in the pan and the pick up looks fine.
Checked the 18 row oil cooler for blockages.
Start engine and it rattles for about 2 minutes as the oil pump seems to only kick in then, and then the rattles stop and sounds fine apart from the low oil presure.
was thinking maybe the 20 year old oil pump has decided it wants to go to the scrap yard heaven.
starts on cold at about 9 bar (after you wait for the oil pump to either start or find some oil) then drops to 1 bar, and then your lucky if you can get the presure to go above 4 bar if you rev it hard.
All this happened after my radtec rad rattled itself to death and burst on the intercooler.
it ran very hot for about two miles where the water temp went sky high and the revs went up and down like a yoyo.
Got home and filled the rad and the engine ran smooth but the oil presure was shot.
but the oil pump as stated just did not want to start until rev to about 3-4000 rpm
Have checked the oil as i wondered if i had fryed the stuff, but it looks as good as the day (two weeks ago) i put it in.
