Pulsey
had the usual code 34 for a while now so couple weeks ago i replaced the sensor which turned out to be faulty so i sent it back and got another new one, long story short i managed to pull the connector off the loom:doh: but after only finding 1 pin in the connector i thought i would redo it all the way back to the ECU, so i now have a new knock sensor and feed from pin 27 out of the ECU. i have also put a a earth on it
after finished it i plugged the ecu back in and deleted the fault code back to 55, went out for a spin and RESULT! was pulling like a train again so theres me happy:-D
a good hour later i thought i would go grab some fuel and go for a drive as its been about 2 weeks being like this. the hesitation/holding back is now back again:doh: but im still getting code 55?
any ideas?
Im thinking of either disconnecting ECU or battery again later and see if it runs better and if it comes back or not
any ideas?
