gunmetalgtir said:
I take it it will look like the one on the R??
Can you just remove it and put say a bleed valve in it's place??
I think it does look very much like the GTiR solenoid, yes.
As for the bleed valve, you can do that but, if you're gonna go the manual boost controller route, I'd go for a relief valve. These work a lot better than bleed valves as, the stay shut until the set boost level is reached. This will give you better spool up and the ability to reach peak boost quicker. From what I understand, they also react faster than bleed valves so, are safer.
I used one on the GT Four and it worked great. It was on the GTiR for a few months too and worked well there.
If your mate wants to go down that route, let me know as, I have the relief valve up in the loft. If he wants it, he can have it for a £10. If he wants it new, go on the GT Four owners club forum as, the bloke who makes them, is on there. I think his user name is 'Kiano' or similar.
Paul
