Standard t28 turbo or upgraded one wanted!!
stee
I need a turbo for my troublesome pulsar lol must be a good one and an upgrade would be great but im on a budget, so what can anyone offer?
wrc
In all fairness to him, there is nothing about the condition of that unit in the auction and 300 quid is a little over the top. Best buy one off pulsarboby mate, in sure he's got a good stock unit in stock, I've just bought a hybrid off him.
kirko
ive got a turbo for sale it was from owen developments its ony low mileage
i have a print out for 428 bhp at 1.7 bar its stock frame so bolts straight on
pm me if interested
wrc
428 bhpizzles out of a stock t28 I'm guessing thats just had a 360 degree bearing fitted??? That's amazing, good show chap.
428 bhpizzles out of a stock t28 I'm guessing thats just had a 360 degree bearing fitted???.
No, it's a hybrid turbo; that's more than just putting a new thrust bearing in it. It will be miss-matched turbine and compressor wheels (i.e. it's made from two different turbos to produce something that isn't a standard part).
wrc
But people do also define a t28 with a 360 bearing as a 'hybrid'. I.e made from non standard parts. I'd be really interested to hear the spec of this turbo?
Yeah, "hybrid" is one of those terms that means different things to different people. - By definition it's simply "re-built in a non-standard configuration", which can be anything from different thrust bearings, but otherwise standard, to the turbine from a 3076 matches with the compressor of a 2854 (because I'm pretty sure you can't buy a 3054 off the shelf).
As far as I'm concerned, just putting the thrust bearing in really doesn't count... especially if it's because they bought a kit off eBay and rebuilt it themselves without rebalancing etc.
As an example; TurboTechnics will build you a hybrid turbo (although I'm pretty sure they recommend a standard configuration unless you're chasing particular characteristics), but they'll also put a 360 degree thrust bearing in. - It's the fact that they've assembled a custom turbo for you that makes it a hybrid rather than whacking the thrust bearing on the end... which may really be because the original parts won't fit a custom unit.
