AJ4
What is the reason for upgrading the MAF to the 300ZX one ? Is it because the throat diameter is restrictive at high flow, or is it because the platinum sensor reaches maximum range ? AFAIK, the Zx one is only bigger by 10mm, so not sure if it is a flow problem.
If its not a flow problem but purely electronic, I was wondering if it was possible to dam the standard one to reduce flow in the sensor chamber, hence increasing the range of the standard sensor. Would need a remap obviously as it would be reading low under normal conditions but I think it would work....
Does anyone know what the restriction actually is ( ie flow or electronic )
Cheers !
Cheers !
