EssexAaron
well ive been doing a few tests and i can say the standard coolers are superb as standard.
ive got 2 ACT gauges rigged in my car and can tell you there is NO NEED for a front mount unless your running massive boost!
and all the bollox on heat soak too, it takes a suprising amount of time for the TOP MOUNT to suffer from heat soak,
for example: a couple of nights ago i did not see temps over 20 degrees at 18psi on full boost, and while cruising was as low as 9.4 degrees!!
im running 18-20psi by the way
also one big thing, the temps are LOWER wen you remove that crome sheild from the edge of the cooler
