Yes as long as you don't repeatedly use them until they overheat.are standard brakes any good ever? even with yellow stuff pads and drilled and grooved disc had this set up on the 200sx and it pulled your face off lol
if you do make it to york the mora have a look at williams brake setup, that was fairly inexspensiveI know some people use the old evo caliper with a spacer and clio 280mm disc, but did anyone ever make just a spacer to use with the standard caliper and clio disc?Seems like the best compromise to me as it could probably be done as a kit for £150-200 inc spacer, discs and pads.
