K
kizzyturbo4x4
i got a friend with an s13 with 180sx sr20det swap.
cars been running fine for over a year.
but suddently when driving it normal and nice one day it just stopped.
We have tryed almost everything i can think of.
the problem seems to be the injectors wont open and let in fuel.
now you all prob. gonna ask about all other things and mostly we have check it.
we got:
- Good spark
- fuel pressure at back of injectors.
- Cas signals checks out ok. (tried two different ones)
- checked engine timing. all ok. cams are in right position and so on...
- Ecu gives no fault codes. also tried other ecu with same results.
- tried to replace injectors. same results
- checked AFM voltage, seems allright. also tried without AFM (tried that before, starts without AFM)
The shite injectors wont open!!!!!
coul any sensor mailfunction or similar cause the engine to close of fueling when crancking?
remember it stopped suddently when driving at constant speed.
please help me cause this really starting to bugger me! :evil:
we got:
- Good spark
