squeaky suspension
keastygtir
I changed my lower arm at the weekend and now I am getting sqeaking from the suspension. It happens even when you are at parking speed and if you bounce the car up and down when stationery.
At first I thought the spring might have moved in the cup but i have had a look and that seems ok.
Any ideas?
Thanks
keastygtir
update, looks like one of the holes for the wishbone mount that goes through the floor has stripped a thread!
Don't drive the car, try getting a longer bolt to purchase on the thread's that may be left if yours are short,or you will have to Buy a helicoil/wurth insert kit. you face crashing the car if you drive it as some one (pobody i think) has done before..M12x1.25 is the size i think
keastygtir
I put a longer bolt in tonight and it tightens first and then goes slacker. I forgot to measure the bolt length while I was there
not necessarily as the captive nut may be spinning which would be a right booger
keastygtir
Well it seemed to tighten a fair bit to the point its probably a couple of turns from being proper tight. Hopefully this means the captive nut is ok? I take it is a nightmare if the captive nut is fooked?
yes not a nice job, but if its almost tightening up then hopefully dannys right in which case you can do as he said!
