where did i mention a smaller trim:?I think what they are getting at is to use a lesser trim turbine wheel to reduce the the flow capacity in hope of removing the boost creep... i think thats the wrong way to go about it to be honest...
how does it?It seems to struggle
Yep had no problems when running the std elbow and 2.5" goose, could run as little as 12psi without creep but did have bad surging issues at part throttle which Stu didn't have with the 3" setup.Dooie Pop Pop said:yeah i did tell you all about this:roll: its what happens when you derestrict the exhaust. Ginga had no problem with a goose and standard elbow but i had problems with my 3inch jobby. im not sure what the minimum boost i could run in that condition was without surging but iirc it was circa 1.5-6 bar, now its around 1.2. this turbo really is as big as you can go with an internal wg.
Dooie Pop Pop said:where did i mention a smaller trim:?
Dooie Pop Pop said:how does it?
im not getting backpressure that im aware of (please explain seeing as its you that thinks its good for 2.1+bar)) and it was holding 1.6 at the redline no problem
im not intending on pushing it any harder to be honest. if anything i' ll be working to gain more from what iv already got;-) its more than enough for a road car and quite a ****ing lot on the track so im happy anyway
