Thanks for replys realy usefull stuff, you were correct was top left fuse thanks.
Rev conter works but speedo doesnt;-(
i have 12volt + and neg wired to my 4 wire convereter and signal wire has 4volts running in and then to my yellow converter wire then into the grey converter wire 4volts.
dont see why it doesnt reed maybe my speedo is fuckd.
i will try going over 6k in 4th later if i can il settle for that as i just want my car delimited.
Anyone know what the volts should read before and after signal wire on the converter?
i also heard a rumour that if the ecu is not getting a speed signal it gives up and only alows u to rev to 6k? i have taken it above 6k in 2nd and 3rd fine so im hoping my clock is fuckd as my ecu is hopefully getting the speed signal?
thanks for any imput cant wait to get the car back togther and on road properly Paul.
