speed limiter
R
r5ben
my cars only going to 125ish mph ???? :oops: i think theres a part to remove this limiter but dont know what its called where to get one from or how to do this can anyone help
I take it that you're not at the redline in 5th when doing 125? If so, you have a Dakar box and can't go any faster without a new gear set.
It's abit high for the limiter, but if it is that you can get hold of a delimiter and convertor to sort you out.
N
N1SMO
i have a spare blitz delimiter if u want to buy it for £30.
R
r5ben
when should the limiter come in ?? i can get it to do it in 4th gear ?? all it does is cut the engine out ? let off and it goes again dont have any probs in and other gears and it does it at the same speed everytime ?? could it be sometin else ??
if it is the limiter i will buy it off ya mate !
R
r5ben
your right lads i watched it last night its about 112mhp every time in 4th gear but the mad thing is that if i shift into 5th it will go past it and do it at 125 mph ??? is there anythin that would make the engine cut out for a sec ??? or is it the limiter 100%
