hello all who can help me sign remove the speed limit
PobodY Moderators Staff member Nov 17, 2013 #2 What ECU etc are you using? - If it's standard, you should be able to wire a de-limiter in.
X xinely New Member Nov 17, 2013 #3 cut wiring ecu number 32 vehicle speed sensor and I still rate limiting in 180 kh.
johnny gtir Well-Known Member Nov 17, 2013 #5 Am i understanding you right you have standard ecu and you want to delimit car dont cut that wire buy a de limiter and it wires in behind the clocks
vss irvine Well-Known Member Nov 18, 2013 #6 If you fit an apexi rsm you can adjust the top speed limiter to whatever you want.
W webadmin Guest Nov 18, 2013 #7 Have a look in this forum. There are lots of posts about this http://www.gtiroc.com/forums/forumdisplay.php?290-De-Limiter-Converter
Fast Guy Moderators Staff member Nov 22, 2013 #9 The ecu uses the speed signal, you might have problems if you cut the wire.
