ok done a search about what you dudes are using for your monsters.
i am having problems with my denso Iridium plug as if you get them wet in any way they don't work again :<
so i went to my local mota mania shop told them the code NGK/BCR8ES had them in stock which were £2.99 bit pricey as they had them on eBay for less money,,
but i wanted them that day..
he asked me what car, i told him a gtir which is running boost he said no way i should put these plugs in has the heat range will not take the plug and are not designed for any nissan he said they will work for about 2 days and then they will stop working i told him i got it from a good place and the gtirs are running 400 pluss b.h.p he said i should only put in iridium had they will take the heat e.g model PFR7B / NGK
i still got them and i know they should be 0.7 mm
but now hes made me think about if i should not but these plugs in my gtir can any one explain to ease my mind about the heat range etc on these plugs cause they are cheap you think they will melt but i know you lads are running more than 400 bhp
