Some noob help needed
Jonnie R
Just trying to get the front hubs off, the only thing thats stopping me is the machanical speedo connection, I've taken the hex bolt out of both but cant seem to disconnect from either hub.
Does it pull straight out? or am I missing something.
Thanks
jjs
i think you mean the abs electrical connector ? once the if it is it should pull out once the bolt is removed .
Mr GTiR
ABS sensors are a bitch to get off. If you follow the cable upto the chassis leg you'll find a plug which you can unplug.
