Trip
When pressing the throttle on neutral, the revs go down to around 600rpm and then go up.
Everything is standard for now (apart from a rebuilt engine)
The only trouble i had, it was idling at 650 rpm so i re-calibrated the TPS to read correct voltage (0.44v idle and 4.23v at WOT) and had to adjust idle screw to get idle to 950rpm.
What i checked are the following:
Fault code and got a clean 55 code
Fuel pressure remains at 3bar
Idle vacuum is -9psi (reading from after the Throttle bodies)
Idle AFR hoovers in the 14.7 range
MAF connecection and ground
Oil pressure when warm is at 40psi (2.7bar)
Any ideas what i should check and/or replace ?
